  3. How to replace foot print for Resistor 0805 to 0402 pac...
  • Replies 7
  • Subscribers 167
  • Views 14574
How to replace foot print for Resistor 0805 to 0402 package
prem20
prem20 over 9 years ago
I am new to Allegro PCB Designer 16.6
How to replace existing  foot print for Resistor 0805 to 0402 package
Prem
  • docb
    docb over 9 years ago
    If you change in the schematic, the netlist calls what footprint you want.
  • prem20
    Is it cannot be replaced from allegro PCB designer tool..?
  • docb
    The netlist is calling a footprint. You could make any footprint have that name, but is it a good idea?
  • redwire
    redwire over 9 years ago
    Allegro is a netlist driven tool.  That means the netlist supplies the footprint information and there is not a normal override as that would break the rules..   As docb stated, correct the netlist and Allegro will correct the footprint.
    But...should you require a hammer there is an option.  Try Logic->Part Logic and follow the prompts.  Good luck!
  • prem20
    Thanks for your reply
    Now it is loading from the  library psm mentioned
    Regards
    Prem
