  3. Cannot load symbol '0402'
  • Replies 7
  • Subscribers 166
  • Views 12248
prem20
prem20 over 9 years ago
I have edited and kept the file name 0402.dra in my custom library folder.
path  is  PSM
If i place the component , it gives the following error
Please help to find the error.
Prem
  • eDave
    eDave over 9 years ago
    Your design is looking for 0402.psm (not 0402.dra). Compile the symbol and put the resultant psm in your psm path.
  • prem20
    Hi I have the following files in the same psm folder path
    1.   0402.dra
    2.  0402.psm
    3.  0402.log
    help me to solve this issue -    Cannot load symbol '0402 -
  • KEN13
    KEN13 over 9 years ago
    Just a thought.  Open the part in you library and do a Save as on the part, using the same name.
    Good luck,
    Ken
  • prem20
    Now it is showing error as
    Could not find padstack SMD27_23.
  • KEN13
    Under User Preferences, Paths, Library,padpath make sure you have your padpath list include the path where the padstack is located.
