  3. Toolbar settings in Orcad Capture CIS V17.2
  • Subscribers 166
  • Views 17533
rrascher
rrascher over 10 years ago
Is it possible to save the toolbar settings in Orcad Capture CIS 17.2?
Every time I start Orcad it comes up with the same settings.
Ralf
  • steve
    steve over 10 years ago
    There is an issue with this and the icon positions are not saved at the moment. Cadence are aware of it. You'll have to put up with this until a hotfix is issued with the fix.
  • rrascher
    I already thought of something like this. As Cadence changed the location of some of their programs,
    they probably do not find their ini-file anymore. Should not happen with such a mature program.
    Anyway, I'll wait for a hotfix.
    Ralf
  • jbateson2
    jbateson2 over 9 years ago
    Same problem here. The documentation is way behind too. Once you figure out some things it's easier to use. Like the fact that many of the settings are under "More Preferences" in the properties menu. Would be nice if they documented that.
  • BrunoZ3
    BrunoZ3 over 7 years ago
    Has anybody found a fix for this?
    It is annoying as hell, and Cadence has "been aware" of it for over 2 years.
  • steve
    steve over 7 years ago in reply to BrunoZ3
    Yes - get the latest hotfix from Cadence support S046. Just tried this and it's working for me.
