  3. Footprint of Si1143 Gesture Control
  • Subscribers 166
  • Views 12189
kapp
kapp over 9 years ago
Hi All,
I was making the footprint of Si114x Sensor. As the dimensions are given in the datasheet
I chose the pad dimensions
Width=12 mils
Height = 16 mils
For making footprint
The package type is 10-QFN, So I chose PLLC/QFP package
Vertical pin count=4
Horizontal Pin count=1
Lead Pitch=20 mils
e1=95
e2 =95
D=79
E=79
then it is showing 6 DRC error.
I don't know, what mistake  that i am doing.
please see the datasheet
www.silabs.com/.../Si114x.pdf
Can somebody suggest me how to resolve this problem?
Thanks in advance.
  • steve
    steve over 9 years ago
    It looks like your pins are the wrong way round, either change the width and length around or open the filename.dra and use Edit - Spin and rotate the pins by 90 degrees
