  3. Non plated holes error is not showing in cadence PCB de...
  • Subscribers 166
  • Views 12574
Non plated holes error is not showing in cadence PCB design
Balaji jogi
Balaji jogi over 9 years ago
 Hi all,
In my design two non plated holes are there. two different traces are passing through the non plated holes in inner layers, but not showing error.
please find attached snap short,
any one help me.
Balaji
  • steve
    steve over 9 years ago
    Go To Setup - Constraint Modes - Spacing Modes and make sure that the Hole to checks are enabled. They are not by default because normally most holes are surrounded by a pad of some description.
  • Balaji jogi
    Hi steve thanks for your suggestion. already i have enabled spacing DRC modes. but no pad in inner layer padstacks , actually no need of pads because that is only non plated holes. please suggest me.
  • steve
    That was the suggestion!! Make sure that they are all enabled (You need to see Ticks in all boxes. If you see a square they are not all enabled so click on the + signs and make sure they are all enabled.
