  3. With relative matched lengths setup in constraint manager...
  • Views 798
With relative matched lengths setup in constraint manager I get "Field solution failed" during routing
Lennie
Lennie over 9 years ago
I setup a number of matched length groups and now I get the message "Field solution failed" during routing. How do I disable this from occurring ?
  • oldmouldy
    oldmouldy over 9 years ago
    Try a Database Check as a first pass, if the issue persists, you will probably need to get the BRD file over to Cadence / Channel Partner support for them to investigate.
  • Lennie
    Thanks. I had a case submitted already.
