  3. Different GND symbols in OrCAD Capture
  • Views 24592
ChrisZhao
ChrisZhao over 9 years ago
Hi experts,
I'm working on board, which has a GND structure like below.  While I found even the symbol name is different (GND_A, GND_B), while the net name is all "0". Can you tell me how to solve this problem?
Chris
  • oldmouldy
    oldmouldy over 9 years ago
    The "0" symbol is design to use with the PSpice simulator which needs a "0" node to function, it was placed in the "capsym" library for convenience. If you use this, instead of the "regular" power symbols, it has an overriding "NodeName" property, value of "0", from the library definition. It would probably be best to replace this symbol in the Design Cache with one of the regular power symbols and then check the power connections in the schematics.
  • ChrisZhao
    Thanks for your comments, I'd like to use the regular power symbols, while I don't know how to differentiate the GND_A, GND_B and GND_C in my design,
  • oldmouldy
    You could display the Name property to distinguish them, if you want a different graphical appearance, you would need to design you own Power Symbols, in a library, New Symbol, Type Power Symbol.
  • ChrisZhao
    I displayed the name of property of GND, it worked.
    Thank you very much!
    Chris
