  3. Cadence Capture 16.6 Menu Problem
  • Views 14802
bieaisar79
bieaisar79 over 10 years ago
I'm using Cadence Capture 16.6 and i prepared a project file. Then i tried to get netlist but Cadence did not show every buttons which must be displayed in menu. I'm using Windows 10 Home Single Language edition. I have observed that the same version and setup file of Cadence 16.6 is running correctly on a computer with Windows 10 Enterprise edition but I'm not sure about problem is causing from it. I'm using 2 graphical card on my computer which are NVIDIA and integrated graphics. I choose NVIDIA and still problem was not be solved. I also tried Windows compability mode and i couldn't get any good result.
This is original display:
This is version on my laptop's display:
As you can see, on my laptop's display there are not some buttons like "Board Launching Options" which must be already exist. If you have an idea about solving this problem i will be happy.
Thank you.
  • steve
    steve over 10 years ago
    win7_fontissue.pdfFirstly 16.6 is not supported on Windows 10 (but in most cases it works without issue). There was an issue on some PC's with Windows 7 where the font scaling was incorrect. Take a look at the attached.
  • oldmouldy
    oldmouldy over 10 years ago
    You might want to check your Windows 10 version, Build 1511 fixed a number of graphical issues that existed with the original Windows 10 distribution, my Windows 10 "winver" is currently showing Version 1511 Build 10586.420
