  3. Avago HCPL 3120 gate driver optocoupler
  • Views 15187
lklopes
lklopes over 9 years ago
I am currently trying to simulate the gate driver optocoupler HCPL3120 in PSpice, but it isn't working. The following error appears:
ERROR(ORPSIM-16145): unknown parameter
+ 2e-3
X_U1.xled.rthermo X_U1.xled.9 N00106 1 TC1
Besides, pins 1 and 4 are NC. If I do not connect them, it does not work as well. Can someone help me on this? The model can be found below.
* HCPL-3120 SPICE Macromodel
* (also applies to HCPL-J312)
* Rev. A
* 09/07
* ZFC
* This is the behavioural model for the above-mentioned part number.
* It is valid for functional simulation over the range specified below.
* (over recommended operating conditions as specified in the datasheet)
* Macromodels provided by Avago Technologies are not warranted
* as fully representing all of the specifications and operating
* characteristics of the product.
* Macromodels are useful for evaluating product performance but they
* cannot model exact device performance under all conditions, nor are
* they intended to replace breadboarding for final verification.
* Copyright 2007 Avago Technologies Limited. All Rights Reserved
* pin1 to pin8
.subckt HCPL_3120 1 2 3 4 5 6 7 8
q2icc 163 84 8 pnpmod
q1icc 84 84 8 pnpmod
xled 5 10 3 2 led
xlimitl 5 10 50 limitl
ehdrive 42 7 40 5 1
eldrive 51 5 50 5 -1
xhlimit 5 10 40 limit
vuvlo 20 5 DC 12
vccinside 22 5 DC 30
dmosl 5 7 dmod
ddrive3 47 46 dmod
ddrive2 49 47 dmod
ddrive1 7 49 dmod
q4icc 122 124 5 npnmod
q3icc 84 122 124 npnmod
qdrive3 8 46 47 NPNMOD
qdrive2 8 47 49 NPNMOD
qdrive1 8 49 48 NPNMOD
xuvlo 5 22 8 21 23 comparator
muvlo 10 24 5 5 nmosswitch L=1e-6 W=100e-6
mdrive 7 52 5 5 nmosmod L=1e-6 W=10e-3
cuvlo 24 5 20e-12
chigh 8 7 1e-12
clgate 52 5 1e-12
clow 7 5 1e-12
chgate 46 7 300e-12
rshort67 6 7 0.0001
ruvlo2 23 21 40e3
r2icc 124 5 600
ruvlo3 23 24 1e3
r1icc 163 122 1e3
rhgate 42 46 1e3
rlgate 51 52 1e3
ruvlo 21 20 1e3
rehdrive 48 7 1.4
.MODEL nmosswitch nmos (vto=+0.7)
.MODEL nmosmod nmos (vto=+0.5 RS=0.9 LAMBDA=0)
.MODEL npnmod npn bf=16
.MODEL pnpmod pnp bf=100
.MODEL dmod D IS=2.22P CJO=1P VJ=.376 M=.139 N=1.07
.ends HCPL_3120
.subckt led 1 3 4 5
gband 1 3 9 1 1
fphoto 1 9 vsense 1
egain 7 4 6 4 1
cband 3 1 140e-12
ithre 3 1 DC 500e-6
vsense 8 4 DC 0
dled 6 4 lednor
doptic 7 8 lednorc
rband 3 1 1e3 TC1=2e-3
rthermo 9 1 1 TC1=-1.5e-3
rled 5 6 1
.MODEL LEDNOR D IS=5E-16 N=2 XTI=3 EG=2.1 BV=5 IBV=10u
+ CJO=60p VJ=.75 M=.3333 FC=.5 TT=20n
.MODEL LEDNORC D IS=5E-16 N=2 XTI=3 EG=2.1 BV=5 IBV=10u
+ VJ=.75 M=.3333 FC=.5
.ends led
.subckt limitl 1 2 3
elimit 4 1 2 7 10
vnegativ 6 1 DC -12
vthreshold 7 1 DC 2
vpositive 5 1 DC 12
dnega 6 3 dmod
dposi 3 5 dmod
r2 4 3 1e3
r1 2 7 10e6
.ends limitl
.subckt limit 1 2 3
elimit 4 1 2 7 10
vnegativ 6 1 DC -10
vthreshold 7 1 DC 2
vpositive 5 1 DC 10
dnega 6 3 dmod
dposi 3 5 dmod
r2 4 3 1e3
r1 2 7 1e6
.ends limit
.subckt comparator 1 2 3 4 5
mcopa 5 6 1 1 nmosswitch L=1e-6 W=100e-6
egain 6 1 3 4 1e3
ro 5 2 10e3
rgate 6 1 10e3
r1n 3 4 1e6
.ends comparator
  • oldmouldy
    oldmouldy over 9 years ago
    OK, not a great effort by the vendor with this model.
    first handle the unused pins:
    rehdrive 48 7 1.4
    rfix1 1 8 1g
    rfix2 4 8 1g
    add the two rfix parts in the HCPL_3120 subcircuit, I used towards the end.
    PSpice handles the TC parameters slightly differently to "default" SPICE, the PSpice format is TC=<tc1>,<tc2>, so locate the TC1 text and edit this to:
    rband 3 1 1e3 TC=2e-3
    and
    rthermo 9 1 1 TC=-1.5e-3
    Save the modified LIB file.
    When you create the Capture part, the default FLOAT for Pins 1 and 4 will be Error, you may need to set these to RtoGND to get the simulation to run, you can do this in the graphical library, OLB, file, or on the schematic pins. The part did simulate for me after the changes noted.
  • lklopes
    Thank you so much
