  3. Unable to use tcom package for Active Tcl 8.6 in cadence...
  • Views 16445
Unable to use tcom package for Active Tcl 8.6 in cadence 17.2 version.
aralex
aralex over 9 years ago
Hi
The tool OrCAD is not able to recognize the tcom package used by Active Tcl. We are using this in the 16.6 version which uses Active Tcl 8.4 however.
At the command window, when I invoke "package require tcom" the following message is returned
Capture> package require tcom
[ 1]couldn't load library "C:/Cadence/SPB_17.2/tools/lib/tcl8.6/tcom/tcom.dll": invalid argument
But the tcom package contents are present at this location.
Does it have anything to do with 32 bit version of Active Tcl 8.6 ? What is the version of Active Tcl that comes default with 17.2 version. i would like to understand the flow
  • oldmouldy
    oldmouldy over 9 years ago
    tcom is almost certainly a 32-bit package which I guess that you have copied into the installation since trying "package require tcom" in the Command Window results in a "package not found" message for my installations. Assuming that you could get the source and necessary tools, you could re-compile tcom for 64-bit but then 64-bit controls would be required by tcom since all of the components running will need to match the 64-bit architecture of the host (Capture) application.
  • aralex
    could you explain how I can re-compile tcom package ? It is a 3.9 version zipped file which I download from the www.vex.net/.../tcom.
    Also what is the Tcl 8.6 version that comes with 17.2 ? I am not clear of the workaround that I need to do.
  • oldmouldy
    Capture 17.2 is a 64-bit application and therefore uses a 64-bit TCL implementation. According to your download link, the download includes a compiled library and source code, which you could compile for 64-bit, with the appropriate tools BUT, even if you do this successfully, the COM capability that you enable will require 64-bit architecture components. Since COM is a long standing Windows 32-bit capability, the chances of finding 64-bit COM components to interact with might be very low, unless you are also building the component for the "other end" of the COM interaction, which seems unlikely from what you have said about COM.
