  3. Auto create report vs statistics for checking unrouted ...
  • Subscribers 166
  • Views 14035
Auto create report vs statistics for checking unrouted nets
kungfu20
kungfu20 over 9 years ago
I am using orcad layout. To check the unrouted nets, if i use Auto-> create reports and select 'Conn unrouted', it shows no unconnected nets. However, if i check the 'statistics'  spreadsheet, under routing statistics, it shows 86% routed.
I am not sure which one to believe. I don't see any ratsnest when all the nets are enabled for routing. Also, the statistics spreadsheet doesn't show which nets are unrouted.
Please help me out.
Thanks.
asenapati
  • oldmouldy
    oldmouldy over 9 years ago
    can you zip and attach the MAX file then? that might provide some clues.
