  3. How should change capture.ini to link my CIP database?
  • Views 15055
jianliu
jianliu over 10 years ago
I have CIP databased installed on a separated server with known IP address and machine name. After install CIP client in my Win10 working station I am requested to modify my capture.ini to change its "Configuration File"'s content to lead to this database. What is the proper format for it? Since it is not on local machine, but on a server with IP, I use
Configuration File = \\MyServerName\CIP-E\Configuration_Files\CIP-E V6.0 CIS DB.DBC
But the tool claims that it can't find it. What is the proper format for this file path?
  • oldmouldy
    oldmouldy over 10 years ago
    Make a copy to the local machine drive and use that copy would be better.
