  3. Should CIP web server and CIP database on a single machine...
  • Views 13337
Should CIP web server and CIP database on a single machine or separated machine?
jianliu
jianliu over 9 years ago
We have CIP 17.2.011 web server and database server separately installed on two virtual machine. I need to update datasheet links with its real location (on DB server's C:\Cadence\CIP-E\Technical_Datasheets). The question is:
1. Should I run Rapther from web server or database server (they are on different virtual machine)?
2. What new path I should use? I put //MyDataBaseServer/Technical_Datasheets with http:// start, but it seems dosn't work.
Any suggestions?
