  3. Update PCB Without Capture Schematic?
  • Subscribers 166
  • Views 14771
tsnamis
tsnamis over 9 years ago
I am in the process of learning ORCAD and need advice on how to best update a PCB. I am using ORCAD 16.5.
I am working on an old project and don't currently have all the files I need (I am hoping this will be corrected in the future). I have a previously designed PCB (.brd file) but no corresponding Capture schematic. The update I want to make is fairly simple (changing a resistor to a potentiometer). Is there a simple way to do this in PCB Editor? Or is creating a new schematic the best approach?
  • docb
    docb over 9 years ago
    You could place the part manually. You'll get an error when you draw the trace.
  • docb
