  3. Display part property if it exists without the name of the...
  • Views 15543
Display part property if it exists without the name of the property
Havel
Havel over 9 years ago
In the Display Properties window (Options > Part Properties > Display) when editing a schematic symbol there is an option "Both if Value Exists," but not one for only the value to show if it exists. Values show up as "Property Name = Value" with the "Both if Value Exists" checked and "<Property Name>" with "Value Only" checked (if nonexistent).
Is there a way to have only the value show up when it exists?
Thanks for your time.
  • oldmouldy
    oldmouldy over 9 years ago
    Which exact version are you running? (Check from Help>About) "Value if Value exists" is certainly a current option for Property display in both the Part and Schematic Editors.
  • Havel
    Allegro Design Entry CIS 16.6-p005 (v16-6-112D) and CIS Plugin 16.6-p001 (v16-6-112A)
  • oldmouldy
    You have a Base Release of 16.6, from about November 2012, you need to get the latest hotfix applied to get this functionality in the Propertyy Display.
  • Havel
    Thank you, using a current version not on my hard drive had this option. Is there also a way to have properties placed in another position if the part is rotated while being placed so that they do not overlap with pins?
