  3. Gerber files are only partly created
  • Views 14598
Jannie
Jannie over 9 years ago
 I completed my board layers only double sided. Using ORCAD 16.6
Ignored a few DRC errors where component were over each other.
When I run the Gerber files all seems OK. When viewing the Gerber layers only the left side top corner is done. The rest of the layer copper are missing
 I tried increasing the boarder outline without any effect.
Any other ideas
  • Soundman99
    Soundman99 over 9 years ago
    Check you Manufacturing\Photoplot_Outline layer. My guess is that has a shape in the corner that you are getting output from.
  • Jannie
    Thanks I had an internal cutout that revered to the boarder outline that blocked the output files.
