  3. OrCAD PCB Designer Professional 17.2: Rectangle vs. Rectangle...
  • Views 15520
OrCAD PCB Designer Professional 17.2: Rectangle vs. Rectangle Shape
RBATES15
RBATES15 over 9 years ago
Can someone please explain the difference between "Add Rect" and "Shape Add Rect"?
  • mcatramb91
    mcatramb91 over 9 years ago
    Add > Rectangle/Frectangle objects are generated/stored with a Height and Width dimension - where as - Shape > Rectangular objects are generated/stored with 4 shape segments.
    The subclass they are drawn on drive whether these objects are filled or hollow, here is some more details:
    • Add > Rectangle = Adds an unfilled rectangle on a particular subclass.  If unfilled shapes are not permitted on the subclass it will automatically change to a filled rectangle. (i.e. Etch subclasses)
    • Add > Frectangle = Adds a filled rectangle on a particular subclass. If filled shapes are not permitted on the subclass it will automatically change to a unfilled rectangle. (i.e. Route Keepin All subclasss)
    • Shape > Rectangular = Similar to adding a filled rectangle on a particular subclass. If filled shapes are not permitted on the subclass it will automatically change to a unfilled rectangle.
    Selecting a Rectangle/Frectangle object using any Shape commands will automatically convert it to a Shape based object with multiple segments.
    Hope this helps,
    Mike Catrambone
  • redwire
    redwire over 9 years ago
    mcatramb91 said:
    Hope this helps,
    Mike Catrambone
    Wow!  That is something I never picked up on in all these years.  Thanks for the explanation!!
  • RBATES15
    Excellent response! Thank you for the help. I will definitely be saving it in my notes.
