  3. hotfix not updating capture?
  • Views 15058
mpfleger
mpfleger over 9 years ago
Hi.
I did a search of the forums for this, but have trouble believing I'm the only one seeing this.
My Capture CIS is telling me that it's out of date at 17.2-2016-S006, with 17.2-2016-S007 being available. This is despite the fact that I've installed two hotfixes since then. It should be showing as 17.2-2016-S008. I searched through the READMEs and found nothing that seems applicable.
Any thoughts would be greatly appreciated :)
Cheers,
M
  • BBlitz
    BBlitz over 9 years ago
    You're not alone. I'm seeing the exact same thing, but I'm a newbie so I figured it's something I'm doing wrong. Will be following this thread closely!
  • oldmouldy
    oldmouldy over 9 years ago
    The Start Page, "Your Version" used to come from parsing the ReadmeCCR.txt in the installation root but, since you can now delete that file and nothing changes, I would say that the "Your Version" mechanism changed at hotfix 6 and isn't being updated - I have just installed a "Base" and added hotfix 8 and it says "Your Version - 6" even though hotfix 6 was not specifically installed. The "Latest Version comes from a server out on the internet so, until "someone" gets this changed, it's going to show 7 as the current version. This has been reported to Cadence but, in any case, this is just the Start Page, a "bunch of web stuff", if you check the Help>About OrCAD Capture, or Help>About OrCAD Capture CIS, it will correctly show the version as "QIR 1" and "ISR 008" with hotfix 8 applied, and the "splash" screen shows that version as well so the tools are all up to date, even if the Start Page isn't showing that.
  • BBlitz
    Thanks, mine is working exactly as you describe.
  • mpfleger
    OK - thanks! Everything I see matches what you've described, as well, so I'll stop worrying about it :)
