  3. Disconnect Hierarchical block from others while preserving...
  • Views 12960
Disconnect Hierarchical block from others while preserving refdesses
michielqpi
michielqpi over 9 years ago
I've got a design with multiple hierarchical blocks and already placed components in the layout. Now I want to swap some connections in only 1 block. Is there some way to disconnect 1 hierarchical block from the others so it basically doesn't link to the others anymore? Because I already already placed some componets, I would prefer if it's possible to preserve the refdesses.
I tried making a new schematic that I later on convert to a hierarchical block in TOP LAYER schematic. (where you can see all the hierarchical blocks) In this schematic I copy all the components from the block I want to convert, but the refdesses automatically change. Even when I use Options / Preferences / Miscellaneous / Preserve reference on copy. This function only works when you are working on the same schematic page?
The only way out I know at the moment is by copying the schematic and changing refdesses by hand.
I use Cadence Capture/Allegro version 16.6-p005.
Edit: I found something over here
09127751201
How can I preserve designators from changes?
Hi In the Orcad capture schematic environment when we try to copy a page in a project file and paste it into an another project all designators automatically changes. How can I preserve them from changes…
By 09127751201 over 12 years ago in PCB Design & IC Packaging (Allegro X) > PCB Design
Latest by bradenmarr over 11 years ago
I'll try that first.
Edit2: the solution suggested in the link above is only for simple Hierarchy designs and not for complex hierarchy designs. So it doesn't work for me.
