  3. Getting the Slot Tolerance to show in the Drill Legend
  • Views 14066
rmerrill
rmerrill over 9 years ago
It is great that within the Pad Editor 17.2-2016 we can define a different X and Y Tolerance on Slots (Thank you very  much).
However, how, using PCB Designer 17.2-2016, do we have the additional column show up within the Drill Legend? I am only getting one of them.
I should also see both of them in the Drill Customization Window, but I do not.
I expected that the "Tolerance" and "Tolerance2" within the .dtl file would give me the two Columns required, but they did not.
Has PCB Designer not caught up with Pad Designer?
  • riklee
    riklee over 9 years ago
    Did you enable Tolerance travel in the legend parameters?
  • rmerrill
    I did not, however, when I did, it does work just fine. Thank You.
    Now I need to go back into the .dtl and change the column heading.
    [I know that the term "Tolerance Travel" should mean something to me but it does not]
