  3. Cannot find PCB editor Lite after installing 17.20.008 ...
  • Views 14238
Cannot find PCB editor Lite after installing 17.20.008 Hotfix
vicvicvar
vicvicvar over 9 years ago
Hi Forum,
I installed the 'Orcad and Allegro Products' Version 17.20 and  the 17.02.008 hotfix.
Before installing the hotfix I could access PCB Editor Lite now its gone.
Where can I find it ?
  • steve
    steve over 9 years ago
    This is normally related to the Windows version you are running. If your on Windows 7 then it should be available under Start - All Programs - Cadence - Release 17.2-2016 - OrCAD Light Products. If you are running Windows 10 then go to Windows button then scroll the list until Cadence Release 17.2-2016 then pick "any" icon and right click - More - Open file location. In the Windows explorer browse back to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cadence Release 17.2-2016 and then you should see OrCAD Light Products and PCB Editor Lite is available. Select the icon and right click - Pin to Start to make is more easily available
  • vicvicvar
    Thanks Steve ! Launcher found
