  3. Microvia and bbvia DRC support
  • Subscribers 166
  • Views 14040
Paul Fitzgeral
Paul Fitzgeral over 8 years ago
First some background. I have an 18 layer board with four sets of microvias and a core bbvia.
L1/L2
L2/L3
L3/L16
L16/L17
L17/L18
Our initial layout had the five sets of vias stacked on top of each other (our vendor preferred this method but had trouble building it). I am tasked with moving the vias apart so none of them are stacked. In essence, I am moving the L2/L3 and L16/L17 vias, therefore unstacking them. I need to turn on a DRC that will flag any stacked vias, as I have thousands on the board.  I have all of the other DRCs working, microvia-microvia, microvia-bbvai, etc (I have the Miniaturization license) but cannot find a DRC that will flag the stacked vias (ex. L1/L2 stacked on top of L2/L3) while not reporting vias that are in the same x/y but have a layer of separation between them. I can have an L1/L2 microvia in the same x/y as the L3/L16 core bbvia location. Please let me know if you need more details.
  • mcatramb91
    mcatramb91 over 8 years ago
    When the BBVia Stagger setting under the Physical Constraints is set to 0 it allows the vias to be stacked without a DRC.
    Enter a value (center to center) to prevent vias from being stacked and it will generate DRC where they are stacked.
    Hope this help,
    Mike Catrambone
  • Paul Fitzgeral
    Hi Mike.
    The problem is I don't want a DRC when the bbvia/microvia are not on consecutive layers. If I have a L1/L2 and L2/L3 microvia on top of each other, I want a DRC to flag that as being stacked. If I have a L1/L2 on top of a L3/L16 via, I do not want this flagged as a DRC as this is acceptable for fabrication.
  • steve
    steve over 8 years ago
    Hi - In The Physical CSet you can set the value Mike is talking about on a layer by layer basis so set this on only the required layers which should give you what you want. There is also a drawing level property (Edit - Properties then select drawing from the Find by name) then choose BBVIA_SEPERATION. You can set this to specify the required layer separation.
