  3. Install 16.6 and 17.2 on the same pc
  • Replies 9
  • Subscribers 167
  • Views 19057
TiBo
TiBo over 8 years ago
Hi
I am currently use 16.6 and want to explore 17.2 but I don't want to give up 16.6 yet because I don't to stop my work flow.
Is there the way that I can install both versions on my PC and switch back and forth as I needed.
Tibo
  • eDave
    eDave over 8 years ago
    Yes. This is common practice and Cadence has tools to allow you to seamlessly switch between versions.
  • TiBo
    Hi Dave,
    Could you tell me a little more? What tools do I have to use?
    TiBo
  • eDave
    Look at switchversion.pdf in your tools/bin folder.
  • oldmouldy
    oldmouldy over 8 years ago
    You don't need the SwitchVersion any longer since 17.2 doesn't rely on the environment settings to run. You can set the environment, with the SwitchVersion after installing 17.2, to run 16.6 and then start either version from the Start menu without further changes.
  • fxffxf
    fxffxf over 8 years ago
    This is not entirely true. If you take advantage of Windows file associations such as when you double click on a brd file in Explorer it will open the Allegro executable, you still need switchversion to modify the association to the desired release.
