  3. Install 16.6 and 17.2 on the same pc
  • Replies 9
  • Subscribers 167
  • Views 19058
TiBo
TiBo over 8 years ago
Hi
I am currently use 16.6 and want to explore 17.2 but I don't want to give up 16.6 yet because I don't to stop my work flow.
Is there the way that I can install both versions on my PC and switch back and forth as I needed.
Tibo
  • DAAS
    DAAS over 8 years ago
    Reading the switchversion pdf it says it will work on all previous releases.....would that go as far back as the 9.2 package? TIA
  • TiBo
    Hi Dave,
    Our IT dept suggested to create a VM and use this VM for new version 17.2, perhaps we have to create a separate set of libraries for the new version.
    What is your opinion?
    Need your advice.
    TiBo
  • eDave
    eDave over 8 years ago
    That unnecessary and doesn't help with the problem of upreving. Just install 17.2 on your pc and take care when opening 16.6 designs in 17.2 to use save-as or rename them before opening.
  • jatins
    jatins over 7 years ago in reply to eDave
    Hi
    I tried using switch version but it doesnt help. Earlier both 16.6 and 17.2 were working fine, but suddenly 17.2 version stopped showin up in Start Window. Dont know why
