  3. How to up date schematic and pcb without re-placing all...
  • Views 12891
How to up date schematic and pcb without re-placing all other parts ?
ismyself
ismyself over 8 years ago
Greetings,
After the parts are placed in PCB environment, I made change in schematic.  How to up date PCB accordingly without re-generating netlist and re-placing all the parts again.
Cheng
  • oldmouldy
    oldmouldy over 8 years ago
    If you changed the schematic, you will need to generate a netlist and load it for those changes to make it to the board. If you are running the "uprev" process from the Capture, Tools>Create Netlist, control, set the Input Board to the current board and the output board to the same, or another name if you want a backup, then the netlist will be loaded into "where you have got to", rather than "starting over". If you are only creating the netlist from Capture and not running the "uprev" from there, create the netlist then open the board file and Import>Netlist (File>Import>Logic for the legacy menus) to load the updated netlist into the open board.
