  3. CIP
  • Views 13812
CIP
Lock2002
Lock2002 over 8 years ago
We installed CIP a few weeks ago but haven’t worked out all of the details yet. We imported the data from our Microsoft Access database into SQL. I have it setup on my computer but haven’t pushed it out to everyone else yet. The problem I just discovered concerns legacy schematics. After I update all parts status and try to pull it into Allegro I get the following error: ERROR (ORCIS-6277): Part C186 on the schematic page - has no part number property. I get this for every part.
In our Access database we used assigned part number to MFGR_PN. In the new database I used PART_NUMBER as the part number property name. Is it possible to assign two different properties to part number in the config file?
  • steve
    steve over 8 years ago
    I'm pretty sure this isn't possible BUT when you import the legacy data using the CIP Importer can you not map the MFGR_PN to PART_NUMBER then going forward you can still just use PART_NUMBER...
  • Lock2002
    I'm afraid I may have to do the entire import process again and continue to use MFGR_PN as the part number.
