  3. Moving Allegro and CIS Settings to New Version Installa...
  • Views 13817
Moving Allegro and CIS Settings to New Version Installation
teevskis
teevskis over 8 years ago
This is probably a simple question for most, but I've had difficulty finding an answer in the Help documents or the forum: How do I move my (numerous) custom settings for Allegro and Design Entry CIS from my existing 16.6 installation to a new 17.2 installation?  I don't intend to keep the 16.6 installation, but I haven't removed it yet because I don't want to lose my settings.  Help?
  • steve
    steve over 8 years ago
    Look under your HOME folder (Type %HOME% into the address bar of Windows Explorer). In this folder will be a pcbenv (for Allegro) and cdssetup (for CIS). For CIS you should just need the capture.ini file. Allegro - will just use the pcbenv folder anyway and there is no different setup locations so your settings should just be there.
  • teevskis
    Awesome, as always steve. One follow-up question: if I had a new machine to install on and wanted to move my settings to it, would I just copy these folders to the new machine before installing Allegro, etc.?
  • steve
    Yes, just make sure that the Computer Environment Variable for HOME is set to the location (Control Panel - System - Advanced System Settings - Environment Variables), then copy the cdssetup and pcbenv folders across.
