  3. pspice error-less then 2 connection at node
  • Views 19914
imdc
imdc over 8 years ago
while simulation in pspice i m getting these error,what is the reason for these errors.
ERROR(ORPSIM-15141): Less than 2 connections at node 6_GND_D.
ERROR(ORPSIM-15141): Less than 2 connections at node N17178733.
ERROR(ORPSIM-15141): Less than 2 connections at node 3_N16703831.
ERROR(ORPSIM-15141): Less than 2 connections at node 3_V_SAFE.
ERROR(ORPSIM-15141): Less than 2 connections at node 13_N16759442.
ERROR(ORPSIM-15141): Less than 2 connections at node 13_VCC_D.
ERROR(ORPSIM-15141): Less than 2 connections at node 8_VCC_A.
ERROR(ORPSIM-15141): Less than 2 connections at node 8_GND_D.
ERROR(ORPSIM-15141): Less than 2 connections at node 9_VCC_A.
ERROR(ORPSIM-15141): Less than 2 connections at node 9_GND_D.
ERROR(ORPSIM-15141): Less than 2 connections at node N17186121.
ERROR(ORPSIM-15141): Less than 2 connections at node N17186124.
ERROR(ORPSIM-15141): Less than 2 connections at node 10_VCC_A.
ERROR(ORPSIM-15141): Less than 2 connections at node 10_GND_D.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_XTAL1_S.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_XTAL2_S.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_N16801115.
ERROR(ORPSIM-15141): Less than 2 connections at node N17190141.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_N16793478.
ERROR(ORPSIM-15141): Less than 2 connections at node N17190139.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_N16793499.
ERROR(ORPSIM-15141): Less than 2 connections at node N17190145.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_N16793510.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_N16816169.
ERROR(ORPSIM-15141): Less than 2 connections at node 11_N16814002.
ERROR(ORPSIM-15141): Less than 2 connections at node 4_XTAL1_M.
ERROR(ORPSIM-15141): Less than 2 connections at node 4_XTAL2_M.
ERROR(ORPSIM-15141): Less than 2 connections at node 4_N16827900.
ERROR(ORPSIM-15141): Less than 2 connections at node 12_VCC_D.
ERROR(ORPSIM-15141): Less than 2 connections at node 12_GND_D.
ERROR(ORPSIM-15141): Less than 2 connections at node N17180848.
ERROR(ORPSIM-15141): Less than 2 connections at node 12_N16764073.
ERROR(ORPSIM-15141): Less than 2 connections at node 5_VCC_D.
ERROR(ORPSIM-15141): Less than 2 connections at node 5_GND_D.
ERROR(ORPSIM-15141): Less than 2 connections at node N17190068.
ERROR(ORPSIM-15141): Less than 2 connections at node 5_N16764091.
ERROR(ORPSIM-15141): Less than 2 connections at node 14-EEPROM_GND_D.
ERROR(ORPSIM-15141): Less than 2 connections at node SCL.
ERROR(ORPSIM-15141): Less than 2 connections at node SDA.
ERROR(ORPSIM-15141): Less than 2 connections at node 15_VCC_A.
ERROR(ORPSIM-15141): Less than 2 connections at node N17201904.
Regards
DC
  • oldmouldy
    oldmouldy over 8 years ago
    You probably have un-modelled pins, pins on the part have no equivalent connection to pins on the model, or possibly an empty model.
