  3. unexpected dialogue box appear while simulation in pspice...
  • Views 13045
imdc
imdc over 8 years ago
why this dialogue box is appearing while simulation.
before some time everything was ok,i was able to see the black window where marker probe signal is displaying
Regards
DC
  • oldmouldy
    oldmouldy over 8 years ago
    Hard to be precise from a picture and no details, but I suspect that the circuit may have failed to converge. In the Simulation profile, Options tab, left-click on AutoConverge and enable the AutoConverge default options. You don't mention which exact version you are running, that could be a factor if you are not running the latest version. If the AutoConverge doesn't help, select the DSN file in the Capture Project Manager window and use File>Archive Project to create a single file (zip) archive of the project and attach it to your post for examination of the actual data and settings being used.
