  3. Active classes and sub-classes?
  • Views 18161
PNO3
PNO3 over 9 years ago
I am somewhat new to making PCBs and components, I am using this video as a guild to learn how to make footprints "
In the video, the first time she makes an assembly outline, she sets the class to Package geometry and the subclass to assembly_top, on the second chip however, when she draws the assembly outline, she uses the class of Board geometry and the subclass to silkscreen_top. I am not sure what the difference is, or which is even correct. Which class and subclass should be used to draw the assembly outline, silk screen, and package boundary?
EDIT: link to video above www.youtube.com/watch
  • oldmouldy
    oldmouldy over 9 years ago
    Apart from Areas, Keepins Keepouts and Boundaries, Classes and Subclasses in PCB Editor are used to control Visibility and Output and PCB Editor does not place any specific significance on what they are used for. By implication, the Package Geometry Class contains the Package Details and the Board Geometry Class contains the Board Details but this is not enforced by PCB Editor. For a Package, there can be Assembly details by layer, typically used for the output of Assembly drawings and there can be Silkscreen details, typically used for the output of the Silkscreen for manufacturing, and there can be numerous other, user defined, Subclasses. Assembly would typically go to Assembly Top (and / or Bottom), Silkscreen would typically go to Silkscreen Top (and / or Bottom) and the Package Boundary, being an area, would be required on Place Bound Top (and / or Place Bound Bottom)
