  3. pspice simulation not proceeding further.
  • Subscribers 166
  • Views 14218
imdc
imdc over 8 years ago
while simulation in pspice ,simulation stuck in between and in the progress bar its showing Pwr Supplies = 50.0000
plz see below image-
what can be the issue and how to resolve it???
Regards
DC
  • oldmouldy
    oldmouldy over 8 years ago
    "something" is preventing the simulator from finding a solution for the Bias Point before starting the Transient Analysis but, without any further information, it's pretty much impossible to identify any "what", or "why", about the issue. You could try "hinting" the Bias Point calculation with some NODESETs and see if that resolves the calculation, or you could try skipping the Bias Point calculation from the Simulation Profile settings and see if a "purely" Transient simulation will run - though you may find that the simulation runs into similar issues. In which case, you will need to get someone to take a look at the actual design data with a view to them investigating the issue in more detail.
