  3. Capture CIS Database setup using Orcale 11g
  • Views 13199
vin5488
vin5488 over 8 years ago
Can we setup Capture.ini file and DBC configuration file to link to database systems like Oracle 11g.
Vinay
  • oldmouldy
    oldmouldy over 8 years ago
    You will need to have an ODBC driver for the Oracle database, 32-bit for 16.x and 64-bit for 17.x, installed. Then configure a datasource through Control Panel for the database using the ODBC drivers and then use CIS Configuration to build the DBC file to map the database fields from the datasource to Capture CIS fields.
