  3. allegro script not exiting, worked in 16.6 but not in 17...
  • Views 13217
allegro script not exiting, worked in 16.6 but not in 17.2
jwhend
jwhend over 8 years ago
Hi all,
We use a script on a command line allegro execution that opens a board file creates PDFs and then exits. This works in 16.6 and if I don't use the -nographic mode:
setwindow pcb
generaledit
create fabpdf    <= SKILL PROGRAM
fillin yes
setwindow pcb
generaledit
exit
fillin no
We run this on the command line:
allegro -nographic -noconfirm -product Allegro_Performance -option Allegro_PCB_HighSpeed_Option Allegro_PCB_Mini_Option -s SCRIPTNAME BOARDNAME
If I remove the -nographic option, the script runs fine. But I don't want the graphic window to open.
Has anyone seen this? Is there a work around?
Jerry
