  3. Passing user defined properties from OrCAD Capture to OrCAD...
  • Views 14274
Passing user defined properties from OrCAD Capture to OrCAD PCB Designer.
klamb
klamb over 8 years ago
I want to pass a property I created in Capture to PCB Designer then output that property to a report. For example if I put the cost or my name as the symbol creator. I want this to show up in a report in PCB Designer. How do I do this?
  • klamb
    go to:
    C:\Cadence\SPB_16.6\tools\capture\allegro.cfg
    add your user property in allegro.cfg
    [ComponentDefinitionProps]
    ALT_SYMBOLS=YES
    component_type=YES
    in Create Netlist > PCB Editor tab;
    check Allow User Defined Property
    export/import netlist as you would normally.
    in PCB Designer reports, you will find your user property under new/edit > Properties tab, locate your user property.
    Keep it crufty,
    Kevin
