  3. BOM_IGNORE property in Capture not passing to reports in...
  • Views 14779
BOM_IGNORE property in Capture not passing to reports in PCB Editor??
klamb
klamb over 8 years ago
I define two resistors with values of bom ignore... in two different ways.
I regenerate my netlist..
it automatically opens my board, so I generate a report with the BOM_IGNORE property.. and nada.
Clearly this simple concept is far beyond my level of competence...
Edit: version 16.6
  • klamb
    go to:
    C:\Cadence\SPB_16.6\tools\capture\allegro.cfg
    add BOM_IGNORE property in allegro.cfg
    [ComponentInstanceProps]
    GROUP=YES
    BOM_IGNORE=YES
    Create Netlist > PCB Editor tab;
    check Allow User Defined Property
    export/import netlist as you would normally.
    in PCB Designer reports, you will find BOM_IGNORE under new/edit > Properties tab
    Keep it crufty,
    Kevin
