  3. DRC in OrCAD Capture
  • Views 13735
vin5488
vin5488 over 8 years ago
Can we give the XY coordinates link(hyperlink) in OrCAD Capture when we run the DRC check, the one which is similar in PCB Editor.
Thanks.
  • oldmouldy
    oldmouldy over 8 years ago
    No, but you can select the "what" you want to browse the DRC Markers from in the Project Manager window, select the "dsn" file entry for the "entire design" for example, and then Edit>Browse>DRC Markers from the menu, you get a "summary list" of DRC Markers, double-click on a DRC Marker entry to go to the DRC Marker in the design.
