  3. Capture CIS, problems creating more than two Variants
  • Views 15800
mvonahnen
mvonahnen over 8 years ago
I have a design and I need to create two different variants from the base design, so I have the core design and two variants.
I am able to create one of the variants by selecting in the core design which parts are not present.  But I can only do this in the core design, the field is grayed out if I go to the individual variants, which means I can only select one set of components which are not present.  Given I have not seen this issue in other forum posts and this is a common thing to do, there must be something in the way I am setting up my variants that is wrong.
Anybody have suggestions on how to fix this?  My version is 16.5
  • Soundman99
    Soundman99 over 8 years ago
    It sounds like you are trying to drive through attribute data. If you view the variant, and then RMB on the part, there should be an option for Variants, and it has all the potential things to do on the variant (Mark as 'DNI', Mark as Preferred, Add Alternate, etc.) This should only apply to the variant being viewed and should not affect your other variant. When you add the DNI to the base, that will apply to all variants.
  • mvonahnen
    Using BOM Variants is new to me, can you go through specifically the commands you use to allow for this?
  • mvonahnen
    My version (16.5) must be different, I only see two options (Set Part as Not Present, Set Part as Present).
  • mvonahnen
    And these commands are only available in the core design, they are greyed out on the Variants I created.
  • Soundman99
    I just noticed that yes, you are 16.5 and on Capture CIS. I'm much more familiar with Concept HDL and 16.6 (we'll soon be moving to 17.2...).
