  3. Importing OrCAD Capture 16.6 into Capture 16.2 using EDF...
  • Subscribers 163
  • Views 7038
Importing OrCAD Capture 16.6 into Capture 16.2 using EDF Importation
ctocci
ctocci over 9 years ago
Thought I had a solution, but NO!  Friend has OrCAD 16.6 Capture and has a fairly hierachial schematic.  So I had him export to an EDF format which worked fine.  However, when I got it, I could import the EDF Capture file, but lost all of the reference designation information.  I DID get ref des info, but it appears to have have started at number "1" on each page and there are 45 pages!!  Needless to say, this causes a severe problem if I am to synchronize the 16.6 Allegro using 16.2 Allegro for corrections.  Right now, due to the schematic have all kinds of DRC errors with duplicate references, etc.  I am stuck.
Any ideas out there?  Or is this a "bridge to far" going between OrCAD 16.6 to OrCAD 16.2 via the EDF translator?
Chris
  • oldmouldy
    oldmouldy over 9 years ago
    Yes, "EDIF Interchange" is not going to work for hierarchical designs but there is absolutely no need to do this since Capture has File>Save As where you can change the "Files of Type" to 16.2 DSN format, which will remove the post-16.2 elements, and then use File>Open>Design in 16.2 with the created DSN file. You may have issues related to Net Groups in the 16.6 design since 16.2 didn't have these and no equivalent.
