  3. Site setting for Drill Chart sizes .DLT
  • Subscribers 163
  • Views 14874
aricbeaver
aricbeaver over 8 years ago
I can go into the installation directory and edit the .DLT files to change the drill chart dimensions. Is there a user preference path that can be used to automatically select site generated .DLT files?
This is where the dialog looks: %CDSROOT%\share\pcb\text\nclegend
This is where I want the dialog to look: %CDS_SITE%\pcb\text\nclegend
Thx,
Aric
  • stump1019
    stump1019 over 8 years ago
    there is a pull down within Allegro under MANUFACTURING -> NC -> DRILL LEGEND, under the template you get to choose which template you want to use.
  • aricbeaver
    stump1019 - I see the template selection but I want to auto populated the "Library" button list using my site.env/CDS_SITE setup
    Solution = change "ncdpath" to include CDS_SITE desired directory
    set ncdpath = $CDS_SITE/pcb/text/nclegend $CDSROOT/share/pcb/text/nclegend
    Two things about this
    1) In the User Preference dialog > Paths > Config shows the "ncdpath" is for .txt files not .dlt files, so that threw me for a loop
    2) That same dialog states changing the "ncdpath" is effective after command is ran, but it indeed needs a restart (manual configuration, CDS_SITE always requires restart, i.e. changes to pcb/site.env)
