  3. Unable to update symbols
  • Views 17818
ClydeS
ClydeS over 9 years ago
I've been fighting this error for about a week without coming up with a solution. I'm trying to update a symbol in my layout with "Place>Update Symbols. It errors out and produces the following log file (I desperately need to solve this issue!)
Sat Apr 29 13:49:27 2017 Page 1
Update Symbols/Modules Logfile
------ Module Refresh Messages ------
SUMMARY:    Updated 0 out of 0 modules
------ End Module Messages     ------
(    Refresh Symbol                                                   )
(    Drawing          : 881-2021-a19.brd                              )
(    Software Version : 17.2S012                                      )
(    Date/Time        : Sat Apr 29 13:49:28 2017                      )
Sat Apr 29 13:49:28 2017				Page     1
------ Symbol Refresh Directives ------
Input design  = 'C:/_Work/Scribner_Associates/881-2021_A3/881-2021-a19.brd'
Output design = ''
Update mechanical symbols              = 'NO'
Update format symbols                  = 'NO'
Update package symbols                 = 'NO'
Update shape/flash symbols             = 'NO'
Update symbol padstacks                = 'YES'
Preserve padstacks replaced on pins    = 'NO'
Reset symbol text and size locations   = 'NO'
Reset Pin Escapes (fanouts)            = 'NO'
Ripup Etch                             = 'NO'
Reset custom drill data                = 'NO'
Symbol list file                       = 'C:/Users/Admin/AppData/Local/Temp/#Taaaaac12968.tmp'
------ Library Paths ------
PSMPATH =  C:/Cadence/SPB_17.2/share/pcb/pcb_lib/symbols
           C:/_Work/_Libraries/Allegro_PCB/PWB-Misc/
           C:/_Work/_Libraries/Allegro_PCB/L-Capacitor/
           C:/_Work/_Libraries/Allegro_PCB/L-Connector/
           C:/_Work/_Libraries/Allegro_PCB/L-Diode/
           C:/_Work/_Libraries/Allegro_PCB/L-IC/
           C:/_Work/_Libraries/Allegro_PCB/L-Inductor/
           C:/_Work/_Libraries/Allegro_PCB/L-Misc/
           C:/_Work/_Libraries/Allegro_PCB/L-Relay/
           C:/_Work/_Libraries/Allegro_PCB/L-Resistor/
           C:/_Work/_Libraries/Allegro_PCB/L-Switch/
           C:/_Work/_Libraries/Allegro_PCB/L-Transistor/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Capacitor/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Connectors/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Crystal/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Diode/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Fuse/
           C:/_Work/_Libraries/Allegro_PCB/SMD-IC/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Inductors/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Misc/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Relay/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Resistors/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Switch/
           C:/_Work/_Libraries/Allegro_PCB/SMD-Transistor/
           symbols
           C:/Cadence/SPB_17.2/share/local/pcb/symbols
           C:/Cadence/SPB_17.2/share/pcb/allegrolib/symbols
           C:/Cadence/SPB_17.2/share/local/pcb/padstacks/
           ../symbols
PADPATH =  symbols
           c:/cadence/spb_17.2/share/pcb/pcb_lib/symbols
           c:/cadence/spb_17.2/share/local/pcb/padstacks
           c:/cadence/spb_17.2/share/pcb/allegrolib/symbols
           ../symbols
------ Symbol Refresh Messages ------
'MPSS100-8'  symbol starting to refresh:
     ERROR(SPMHNI-254): Unable to load symbol, 'MPSS100-8': 'ERROR(SPMHA1-161): Cannot open the design database file ... run stand~
     alone dbdoctor on the file.'.
         due to WARNING(SPMHUT-127): Could not find padstack 043X080R_2.
------ Pad Stack Refresh Messages ------
'040X080R_1'  pad stack refreshed successfully.
'040X080S_2'  pad stack refreshed successfully.
----- Symbol Update Summary ----
Refresh symbol errors; due to these errors this design is NOT updated.
       1  errors detected.
       0  warnings detected.
  • Soundman99
    Soundman99 over 9 years ago
    two thoughts: 1) make sure that the padstack 043X080R_2.pad is in your padpath 2) have you followed the suggestion and run dbdoctor on the symbol? Open a standard command prompt and use "dbdoctor <dir_path>\MPSS100-8.dra" I'm assuming that you've done both of those things first, but just want to make sure. After that, I would try to open the .dra on it's own and see if there are any errors/warnings when you open the symbol.
  • RBATES15
    RBATES15 over 9 years ago
    It looks like you are just trying to update a padstack. You can update a single or all instances of a padstack the board file by right clicking on the pad. I don't normally recommend this as it results in the library not matching the board file which can cause problems but give the time you've spent on this issue a bruit-force method is worth a trying so you can move on.
