  3. Automatically Updating Page Numbers in Capture
  • Views 23891
RBATES15
RBATES15 over 8 years ago
I added a new page to my existing schematic and it started over at page 1 of 1. I know I can manually change the page numbers.  Is there an automated way to change the page numbers so they are all grouped together?
  • steve
    steve over 8 years ago
    Yes run the Tools - Annotate command.
  • RBATES15
    Is there a way to update the page numbers without updating the reference designators? The layout is complete.
  • Wild
    Wild over 8 years ago
    What I do:
    High light the DSN in the project tree
    Then I click Edit -> Browse - Title Blocks -> Use occurences (Preffered) -> OK
    Select all Pages
    Edit -> Properties
    Then I edit the pages in the order I want them in.  The Field Name is Page Number
    Also ensure that the Page Count Field is correct.
    BTW this works for reuse design projects, it will bring in all pages internal and external to the design.  I can manage exactly the page order I want regards of the ordering in the design project window.
    Wild
  • steve
    The Annotate command is the way to go. If you have a design that has the layout complete and all the refdes are already done, use the Annotate command in incremental mode and it will only do the page numbers, Or - Use Wild's method which is a manual method.
