  3. Ask for help about Capture TCL/TK command's usage( GetDBCName...
  • Subscribers 163
  • Views 1771
Ask for help about Capture TCL/TK command's usage( GetDBCName in CPMgtCfg class )
cldr
cldr over 9 years ago
HI! Everyone!
I'm a starter and want to use Capture TCL/TK commands for doing some automate function in Capture Schematic design.
I want to update all the place-instances' user prop. from SQL server( config in DBC ). Maybe I can do it by "CTRL-L" command to LINK to database one by one, but so many instance...it's a hard work, so I need to make a TCL command and do it automately.
I think  I need to get access to the database part which is  config in "capture.ini" and "demo.dbc" files.
I don't know where can I start firstly, as there was less infomation, even searching in google. So, I learn about it in "OrCAD_Capture_TclTk_Extensions.pdf", and find something may help.
In the PDF, there is some functions about the database operation in  CPMgtCfg class such as GetDBCName, GetFirstTable, GetNextTable...
But, I don't know how to use the functions, there is little details.   Is there anyone help? Thanks a lot!
  • cldr
    hey guys!
    My work is going ahead now. I can get the "CPMgtCfg" from "OrCISGetDbcConfig" function, and also get the DBC config file path, SQL database' records.
    But still can't get (Query) each data from sql. Any help will be greatful!
    Logs as belows,
    Capture> set lCfg [OrCISGetDbcConfig]
    _2099412700000000_p_CPMgtCfg
    Capture> set lString [::CPMgtCfg_GetIniDBCName $lCfg]
    _e078d12600000000_p_CString
    Capture> puts [DboTclHelper_sGetConstCharPtr $lString]
    X:\LIBRARY\SZ_LIB.DBC
    Capture>
    Capture> CPMgtCfg_GetTotalRecords $lCfg
    1244
    Capture>
    Capture> puts [DboTclHelper_sGetConstCharPtr _c07b262700000000_p_CString]
    Capacitor
    Capture>
    Capture> CISExecuteQuery
    Capture>
