  3. How do I export a board shape from Allegro to a Visio compatible...
  • Views 14759
How do I export a board shape from Allegro to a Visio compatible file format?
Frank Kern
Frank Kern over 8 years ago
I need to extract an image of the board shape from Allegro, retaining size information, then import into Visio. Can anyone provide information on how this can be done?
  • redwire
    redwire over 8 years ago
    DXF format is common between the two.  You might need to install the Visio DXF reader add-in based on your version which is free.
  • redwire
