  3. Capture 17.2
  • Views 13119
Capture 17.2
VinCT
VinCT over 8 years ago
Installed 17.2 and I cannot set up a .DBC file. I get the following error :
ODBC Error Code: -1  Description: The specified DSN contains an architecture mismatch between the Driver and Application
Any suggestions appreciated.
16.6 is running well on the same PC.
  • SteveNZ
    SteveNZ over 8 years ago
    Hi Vincent,
    16.6 is a 32 bit application the database driver is also 32 bit. You need a 64 bit database driver for 17.2 to read the CIS database.
    Steve
  • VinCT
    Thanks Stephen, appreciate the input. I will check my drivers if I can, nothing is easy here we do not have any admin rights.
