  3. tcl Orcad 17.2 : RuntimeError Command Requires Schemati...
  • Views 15070
tcl Orcad 17.2 : RuntimeError Command Requires SchematicView
spirentgabe
spirentgabe over 8 years ago
I'm using Orcad 17.2 and I'm trying set a bunch of part properties to be visible (VALUE_ONLY) or not (DO_NOT_DISPLAY).  I have a function that works for a single selected part instance.  I'd like it to work on all the parts on the whole design.  I have some code for an unrelated function that traverses all the parts in a design and I copied that method of traversing the design but when I run it I get the error:
I get a similar popup error if I try to manually change the display properties from the "Edit Object Properties" window.  The only reference I found in the docs about "SchematicView" is a function that returns a boolean to check if SchematicView is enabled or not.
Is there a way to traverse all the parts where it does it in SchematicView mode?  The method I use to traverse the design is copied from Orcad TCL/Tk Extensions manual rev 1.2 (sections 3.2.2 and onward).
  • oldmouldy
    oldmouldy over 8 years ago
    You can only change "Display" properties in a Schematic (Page) View, hence the runtime error.
  • oldmouldy
