  3. Edit Netlist
  • Views 14594
Edit Netlist
Filo88
Filo88 over 9 years ago
I'm drawing an PBC (my second board) and I already made the routing in Orcad PCB designer.
I need to add a new component in the circuit and edit the netlist. Is possible to import a new netlist without have to made a new board?
I tried it but I received error when I created the new netlist.
But If I create the new netlist in a new board (empty) I don't receive any error.
Thanks in advance for the help.
Filo
  • redwire
    redwire over 9 years ago
    Of course.  There is no need to make a new board.  New netlist should just add to the board.  Unless something is seriously wrong with your process this should be a push-button update.  What error are you getting?
  • Filo88
    Thank You for your reply.
    In this days i tried al lot to import the new netlist end I became aware that I had a error in an footprint.
    But I don't understand the the option " Run ECO to Layout" in the Layout Menu. What does it do?
