  3. Why do some properties not get transferred to the schematic...
  • Views 13345
Why do some properties not get transferred to the schematic from the library part?
Gabor Sz
Gabor Sz over 8 years ago
I'm fairly new at OrCAD Capture, and maybe I'm going about things wrong.  In any case I'm trying to build up a library that contains the complete information for the parts I use in my designs.  What I find is that when I then place the parts on a schematic page, there are properties that I added to the library part that don't make it into the schematic.  For example, I find that I can add the property "PCB Footprint" to the part in the library and assign it a value like "SOT-23".  Then I place the part in the schematic and I see that the value for PCB Footprint is blank in the schematic instance.  Is this a normal behavior or am I doing something wrong?  If it is normal behavior, then what's the right way to save complete components including all required properties so they can be re-used in another design?
  • oldmouldy
    oldmouldy over 8 years ago
    In the specific case of "PCB Footprint", that is a Package property, Options>Package Properties with the Part open in the Library, so you would only need to specify the value and not add the property. If you added the property through Options>Part Properties, that might well explain why you get an empty property (because the Package Property is still blank)
  • oldmouldy
