  3. Guide to Allegro Macro Language changes
  • Views 10794
FormerMember
FormerMember over 8 years ago
Prior Allegro releases used a much different macro language that (for the most part) still functions. I have many such macros I use constantly.
The macro language changed at some point (V16 onwards?) and recording a macro results in a .scr file recorded in this newer language (tcl?).
The newer syntax is very cryptic (reference manual?). Worse, when changing the color visibility of something in the color dialog box, as far as I can tell this newer syntax does not select the visibility state as 'ON' or 'OFF', it only toggles its status.
So for example, a script that adds the top_bounds to the current view is no longer possible. I can only toggle it.
I've tried extending old scripts by using the older syntax, but this seems to be hitting some limitations, in that newer classes (like 'Embedded Geometry') are not recognized.
So, is there a way to make an objects color visibility deterministic in the new language? Is there a way to reference newer objects in the old syntax?
e.g., I want this script (including he newer lines in bold) to work:
Version 14.2
scriptmode +invisible
setwindow pcb
trapsize 97
color
setwindow form.cvf_main
FORM cvf_main class_list Geometry
FORM cvf_main package_geometry/place_bound_bottom/visible NO
FORM cvf_main package_geometry/place_bound_top/visible YES
FORM cvf_main embedded_geometry/place_bound_L4-flex/visible NO
FORM cvf_main embedded_geometry/place_bound_L3-flex/visible YES
FORM cvf_main apply
FORM cvf_main ok
For reference, toggling the visibility of the boundaries on L4-Flex looks like this in the newer syntax:
version 17.2
setwindow pcb
trapsize 2136
# Macro file: coordinates are relative to pick on replay.
color192
QtSignal CVDLayerSplitter CVDLayersTree itemSelectionChanged Geometry "Embedded geometry"
QtSignal CVDLayerTable CVDLayerTableDelegate clickedBox 9 0
QtSignal CVDLayerSplitter CVDLayerTable dataChanged Place_Bound_L4-flex EmbGeo
QtSignal CVDLayerSplitter CVDLayerTable dataChanged Assembly_L4-flex EmbGeo
QtSignal CVDLayerSplitter CVDLayerTable selectionChanged
QtSignal ColorVisibilityDialog CVDApplyButton clicked
QtSignal ColorVisibilityDialog CVDOkButton clicked
Not being able to set absolutes is a killer. Before, I could turn on the top bounds, the bottom bounds, both top and bottom or neither by running one macro for each of these four options. This is not possible with only a toggle command.
Maybe I am missing something obvious here. If so, I apologize in advance :-)
-Colin
  • eDave
    eDave over 8 years ago
    Why not use Skill?
  • FormerMember
    Probably because I'm too lazy (or too old) to learn skill :-)
    Seriously though, the ability to record macros on the fly is nice and I'm not even slightly proficient in skill's syntax. I have over 200 Allegro macros that I use regularly and I really don't want to convert them to skill if they still do what I need them to do.
    [Add in Orcad Captures change to tcl and there is yet another new-to-me scripting language I need to learn!]
  • RandyR
    RandyR over 5 years ago
    I don't have the embedded license, but try something like this:
    version 17.2
    setwindow pcb
    trapsize 12857
    generaledit
    setwindow form.mini
    FORM mini class PACKAGE GEOMETRY
    FORM mini subclass PLACE_BOUND_TOP
    FORM mini subcolor 1
    setwindow pcb
    Note:  "subcolor 1" to make visible, "subcolor 0" to make invisible
