  3. TCL to change user properties
  • Views 14579
fluxonator
fluxonator over 8 years ago
Hi All!
I have a problem writing a TCL script to change the display format of a user property dependent on its value.
Each symbol in my Capture symbol library has two attached properties called "BOM_IGNORE" and "DNP". The final aim is to set the display format of the DNP property dependent on the BOM_IGNORE property. But I already fail to access/display the property. It got it to work in a non-hierarchical design but not in a hierarchical one.
Here is my TCL code:
proc putsProps {} {
  set lStatus [DboState]
  set lNullObj NULL
  set lDesign [GetActivePMDesign]
  if {$lDesign != $lNullObj} {
    set occurenceIter [$lDesign NewOccurrencesIter $lStatus]
    set lOcc [$occurenceIter NextOccurrence $lStatus]
    # iterate over occurrences
    while {$lOcc != $lNullObj} {
      # get corresponding instance to occurrence
      set lPartInst [$lOcc GetPartInst $lStatus]
      if {$lPartInst != $lNullObj} {
        set lPropsIter [$lPartInst NewDisplayPropsIter $lStatus]
        set lDProp [$lPropsIter NextProp $lStatus]
        # iterate over display properties of instance
        while {$lDProp != $lNullObj } {
          # get and output the name of display property
          set lName [DboTclHelper_sMakeCString]
          $lDProp GetName $lName
          set lNameString [DboTclHelper_sGetConstCharPtr $lName]
          puts "Name of PartInst Property = $lNameString"
        delete_DboDisplayPropsIter $lPropsIter
    delete_DboDesignOccurrencesIter $occurenceIter
As a result I get the following output:
Name of PartInst Property = Part Reference
Name of PartInst Property = Value
So I can access the Part Reference and the Value but neither the BOM_IGNORE nor the DNP property.
What am I doing wrong? Can someone point me into the right direction?
Thanks in advance,
Martin
  • FrancoisD
    FrancoisD over 6 years ago
    Hi Martin,
    I know this is old, however I wanted to point out that you are iterating over "Display" properties, not "User" properties.
    Change the following lines:
    to:
    set lPropsIter [$Part NewUserPropsIter $lStatus]
    set lDProp [$lPropsIter NextUserProp $lStatus]
    And the following lines:
    to:
    delete_DboUserPropsIter $lPropsIter
    If BOM_IGNORE is defined as a "User" property then you should be able to show its value.
    Francois
