  3. Spacing C-set for shape instance
  • Subscribers 162
  • Views 3126
FormerMember
FormerMember over 9 years ago
I need to draw a dynamic ground shape that has a larger clearance than the other ground shapes (same net name) on the board.
Is there a way to apply a C-set to one shape instance, rather than by net class or region?
I tried assigning the Dyn_Clearance_Oversize to just that shape, but this has no effect.
  • oldmouldy
    oldmouldy over 9 years ago
    Try hovering the mouse over the Shape with Shapes enabled in Find, then right-click>Property Edit, set the "Void_Same_Net" property to the Shape then OK and Done. Same Net Spacing / Shape to Shape will then be in play and you should then be able to get "Dyn_" property values to do something about the Clearance.
